forum.skoda-club.ru • Просмотр темы - Вывод диагностических данных на КПК
Сообщение TallioN » Сб, 27 окт 2007, 20:12
Mr.Tvister писал(а):Комбинации кнопок в студию :)
To enter the climate settings, press ECON and the top right button in the middle cluster of 4 buttons.
To change the main channel (large number on passenger side LCD), use the passenger side temp dial. To change the sub channel (the small number to the top right of the main number), use the fan speed dial.
To exit press AUTO and ECO simultaniously.
Main channel: 0 - System data
0 Number program
1 Left ERL
2 Skillful ERL
3 Point of job accensione/avvio
4 I recirculate automatic rifle (motor)/I recirculate automatic rifle Bit
5 Heating from active detention
6 Air Quality (7 = fresh air)
7 Deriving
8 Acronym country
9 Sensor zone head
Main channel: 1 - UIF
0 Inner temperature (°C)
1 Surface Temperature (°C) (I think it means external)
2 Temperature piastrine in platinum (°C)
3 Corrector piastrine in platinum (°C)
4 Uif-Sonnenint
5 Corrector radiation (°C)
6 dynamic corrector (°C)
7 OrrettoreC I recirculate (°C)
8 thermal corrector (°C)
9 Compensation ignition (°C)
Main channel: 2 - Sensor radiation SX
0 Radiation not delayed (W/m2)
1 Corrector radiation for regolator temperature (W/m2)
2 Corrector radiation for impeller (W/m2)
3 Value TO
Main Channel: 3 - Sensor radiation DX
3 Value TO
Main Channel: 4 - External Temperature
0 External temperature (°C)
1 Temp. External line CAN (°C)
2 Temperature inhaled air climate (°C)
Main Channel: 5 - Theoretical temperature SX
0 Theoretical Temp. air in escape SX (°C)
1 Theoretical difference between temp. and temp. effective (°C)
2 Value regulation the sx. (½% )
3 Pi-Stell-Max (½%)
4 Defrost SX
Main channel: 6 - Found temperature SX
0 Temp. Found SX (°C)
1 Temp. Feet SX (°C)
2 Temp. Facade SX (°C)
Main channel: 7 - Theoretical temperature DX
0 Theoretical Temp. air in escape DX (°C)
1 Theoretical difference between temp. and temp. effective DX (°C)
2 Values of regulation regolator (½% )
3 Pi-Stell-Max (½% )
4 Defrost
Main channel: 8 - Found temperature DX
0 Found Temp. air in escape DX (°C)
1 Temp. Feet (°C)
2 Temp. Facade (°C)
Main channel:9 - Theoretical temperature evaporator
0 Theoretical temperature evaporator (°C)
1 Theoretical difference between temp. and temp. effective evaporator (°C)
2 Values of regulation evaporator (5mA/Dig)
3 Modality Regolator evaporator (you see under)
Main channel: 10 - Effective temperature evaporator
0 Effective temperature evaporator (°C)
1 Pressure coolant climate (bar)
2 Medium temperature coolant climate (°C)
Main channel:11 - Climate control compressor
0 Power theoretical electrical worker
1 Power effective electrical worker
2 Power electrical worker max
3 Kompressor PWM (0... 200) (Dig)
4 Power electrical worker offset compressor
5 Values power electrical worker
6 Code disinserito compressor (you see system)
Main channel:12 - Climate control impeller
0 Theoretical tension of the electric impeller (V)
1 Manual regulation
2 Code anomaly
3 Reduction impeller (V)
4 Impeller offset (0.1V)
Main channel: 13 - Temperature bocchette air SX
0 Formattato theoretical value (%)
1 Real theoretical value temp. Bocchette sx.(Dig)
2 Confirmation el. temp. Bocchette sx (Dig.)
3 The maximum limit temp. Bocchette sx. (Dig)
4 Limit min. temp. Bocchette sx. (Dig)
Main channel: 14 - Temperature bocchette air DX
1 Real theoretical value temp. Bocchette dx (Dig)
2 Confirmation el. temp. Bocchette dx (Dig)
3 The maximum limit temp. Bocchette dx (Dig)
4 Limit min. temp. Bocchette dx. (Dig)
Main channel: 15 - Piedi/centrale temperature bocchetta
1 Real theoretical value temp. Bocchetta centers them (Dig)
2 Confirmation el. temp. bocchetta centers them (Dig)
3 The maximum limit temp. bocchetta centers them (Dig)
4 Limit min. temp. bocchetta centers them (Dig)
Main channel:16 - Defrost Shovel
1 Theoretical value real Defrost shovel (Dig)
2 Confirmation el. Defrost shovel (Dig)
3 Limit maximum Defrost shovel (Dig)
4 Limit min. Defrost shovel (Dig)
Main channel: 17 - Shovel I recirculate inner
1 Theoretical value real shovel I recirculate (Dig)
2 Confirmation el. shovel I recirculate (Dig)
3 Limit maximum shovel I recirculate (Dig)
4 Limit min. shovel I recirculate (Dig)
Main channel: 18 - Shovel cold air
1 Theoretical value real Shovel cold air (Dig)
2 Confirmation el. Shovel cold air (Dig)
3 Limit maximum Shovel cold air (Dig)
4 Limit min. Shovel cold air (Dig)
Main channel: 19 - Data Motor
0 Vehicle velocity (km/h)
1 Vehicle velocity (Mph)
2 Motor temperature (°C)
3 Engine speed (RPM)
4 Air con compressor speed (RPM)
Main channel: 20 - Data sent by CAN
0 Additional heating (upon request) (1 = on)
1 Confirmation el. PTC (1 = on)
2 Power el. effective PTC
3 % air demanded from radiating climate (%)
4 Relationship % of radiating peak air (%)
5 No performance demanded to the disp. of heating (1=no performance heating)
Main channel: 21 - Ripartitore of air Climate
0 Defrost (%)
1 Facade (%)
2 Feet (%)
3 Bocchetta areazione (%)
4 I recirculate fresh air/cleaned up (+ bocchetta...) (%)
5 Appraisal sensor (%)
Main channel: 22 - Data timer
0 Period of pause (min)
1 Motor operating time (sec)
2 Operating time with inserted key (Sec)
Main channel: 23 - Special channel
0 Sensor inner lighting system (Dig)
1 Air quality sensor
Main channel:24 - Version software
0 Development state
1 Software version
2 Type SW
3 Keep Frozen (0/1 = Values of refrigeration come maintained ad.eccezione.della Diagnosis )
4 Version K Matrix
5 EEP- Testflags
6 It codifies Vag (2)
Main channel: 25 - Test channels
1 - 9
Main channel: 26 - Parameters for surveys on crystals
0 Delay (sec)
1 Passo/udm (digit)
2 The minimal limit (digit)
3 Limit max. (digit)
4 Passo/udm on HellaKit
Main channel: 26 - Bocchetta direct areazione
1 Theoretical value real Bocchetta direct areazione (Dig.)
2 Confirmation el. Bocchetta direct areazione (Dig.)
3 Limit max. Bocchetta direct areazione (Dig.)
4 Limit min. Bocchetta direct areazione (Dig.)
Main channel: 28 - Umidita
0 Theoretical Umidita (%)
1 Relative Umidita on temperature UIF (%)
2 Temp. Crystals WSS (°C)
3 Temperature condensation point (°C)
4 Difference temperature of the melting point (°C)
Main channel: 29 - Crude values umidita
0 Temp. Crystals, corrected (°C)
1 Temp. Crystals, not corrected (°C)
2 Sensor umidita (%)
3 Temperature sensor (°C)
4 Temperature condensation point (test measure) (°C)
5 Code anomaly
Main channel: 30 - Values indicated to you umidita
0 Value sensor termofilo (Dig.)
1 Temperature rif. termofilo (Dig.)
2 Periodic duration umidita (10 (to the power of -4) sec)
3 Temp. Reference umidita (Dig.)
4 Umidita Rel. on the sensor (%)
5 Temperature sensor umidita (°C)
6 Temperature crystals (not corrected) (°C)
TallioN
Сообщение AlexLion » Пн, 29 окт 2007, 12:28
Интересно! А как функциональность по сравнению с этим.. "vag com"? или как его зовут? (с) А стабильность ПО? Но цена вроде адекватная.. По крайней мере, для меня пока что понятия "климатроник" и "абсолютно бесплатно" расходятся более чем на 100уе ;)
AlexLion
Сообщение TallioN » Пн, 29 окт 2007, 13:01
AlexLion писал(а): А как функциональность по сравнению с этим.. "vag com"? или как его зовут?
VAG COM, помимо считывания и стирания кодов неисправностей, позволяет менять настройки всех модулей. Например, активировать круиз-контроль, менять язык голосового общения у штатного bluetooth, выбирать тон писка оригинального парктроника и многое многое другое
TallioN
Сообщение aleksan_dr » Пн, 29 окт 2007, 14:17
aleksan_dr
Сообщение aleksBlackRS » Вт, 30 окт 2007, 22:18
Сегодня проверяли и это все действительно работает-показывает.Осталось перевести все это на русский язык что б знать шо кажеть!!:)))))))
aleksBlackRS
Сообщение Nunsellmo » Вт, 19 янв 2010, 22:33
а как активировать данную функцию на раздельном климате ? климатронике ?
Nunsellmo
Сообщение Serj-77 » Вт, 19 янв 2010, 23:19
А кроме температуры он может показать еще какие нибудь параметры работы двигателя,?по моему нет.При ремонте климата это может помочь
и все собственно.С ваг ком и аналогичными вещами сравнение не актуально.Это касается и рекламируемых девайсов.
Serj-77
Re: Вывод диагностических данных на КПК
Сообщение werwolfx » Ср, 12 май 2010, 16:06
А какая комбинация кнопок на Octavia FL ??? на раздельном климате???
A5 FL 1.4 DSG7 2010
werwolfx
Сообщение kik 88 » Ср, 14 дек 2011, 10:05
никто так и не ответил про комбинацию на FL??
kik 88
Сообщение Robbin » Ср, 14 дек 2011, 19:06
Потому что нет такой комбинации
Re:
Сообщение vasiljev » Вс, 19 фев 2012, 16:21
Timur_UA писал(а):Б.... если подойдёт- я куплю. Купил. Ничего так, удобно что показывает когда двигатель прогрет до 35 градусов и можно начинать движение. Ошибок у меня нет, поэтому сказать ничего не могу.
Тимур, а на какой машине проверял? У них в каталоге только окта до 2008 и рс. Я попробовал на свою - не идёт, пишет мол нет соединения с эбу, проверяйте подключения, включено ли зажигание.....При этом, адаптер по блютузу видит. Разработчики отвечают, что эбу возможно не поддерживает протокол CAN по OBDII.
Сорри, что откопал старый пост.....
vasiljev
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 0
