Владельцам Climatronic (коды)
Незнаю было ли на форуме или нет, нужно кому или нет.
Но найдено следующее.
Press the following Keys at the same time: Fan Down + Cold + Econ. Press Red and Blue to display alternative channels,
После нажатия соответствующей комбинации выскакивает меню диагностики.
Вот какие каналы за что отвечают:
1 interior temperature °C
2 sun intensity retarded * 10 W/m2
3 sun intensity * 10 W/m2
4 external temp retards °C
5 external temp. Bumper °C
6 external temp. Suction port °C
7 blowing out temp. Floor space °C
8 blowing out temp. MAS °C
9 Target Geblaesespg. * 0.1 V
10 Be Geblaesespg. * 0.1 V
11 SOLL_Temp. flap Dig.
12 SOLL_Zental flap Dig.
13 SOLL_Uml./Staul. flap Dig.
14 SOLL_Fussr./Def. flap Dig.
15 engine running time S
16 driving speed km/h
17 START_AP Dig.
18 Uml./Frischluft threshold Dig. to
19 compressor out code see plant
20 PI_STELLMAX Ausbl moving. Dig.
21 INT_STELL Ausbl moving. Dig.
22 Epsilon Ausbl moving. Dig.
23 actual blowing out temp. °C
24 target blowing out being. °C
25 - Last detent temp flap Dig.
26 RMP_Temp. flap Dig.
27 + last detent temp flap Dig.
28 - Last detent central flap Dig.
29 RMP_Zental k. Dig. Dia. g. channel INDICATED SIZE OF DIMENSION 30 + last detent central flap Dig.
31 - Last detent Uml./Staul. flap Dig.
32 RMP_Uml/Staul. flap Dig.
33 + last detent Uml./Staul. flap Dig.
34 - Last detent Fussr./Def. flap Dig. 35
RMP_Fussr./Def. flap Dig.
36 + last detent Fussr./Def. flap Dig.
37 service life min. (255 = no telegram)
38 compressor PWM Dig (0... 200)
39 target evaporator being °C
40 actual evaporator temperature °C
41 i-placing evaporator Dig.
42 Epsilon evaporator Dig.
43 refrigerant pressure without
44 BiLevel/MAS threshold Dig. 45 engine temperature °C
46 actual compressor stream mA
47 target compressor stream mA
48 compressor max. stream mA
49 compressor number of revolutions 100/min
50 radiator exhaust heading for signal %
51 windshield wiper mode 0 = out; 1 = interval; 2 =
52 Fdk correction in Abh. of the windshield wiper - Dig.
53 Geblaesespg. correction in Abh. of the Scheibenw. * 0,1V
54 basic number
55 Volkswagen number
56 HELLA number
57 Test-1
58 Test-2
59 Test-3
60 Test-4 extended diagnostic channels for CAN variants dia. g. channel INDICATED SIZE OF DIMENSION receive data
61 freely
62 clamp 15 bits
63 hot light bit
64 external temp filtered °C
65 climatic disconnection bit 66 engine speed x10 U/min.
67 Dimmung %
68 characteristic diagram cooling bit
69 land variant the 2 = USA/1 = Japan/0 = remainder of transmit data
70 freely
71 Zuheizer (PTC) bit
72 compressor (compressor) bit
73 heating from bit
74 external temp. Wasserkasten not filtered °C
75 compressor load Nm 76 blower load of %
77 radiator exhausts of %
78 customer service errors bit (error memory)
PS думаю модераторы разберуться нужна данная тема или нет
17 START_AP Dig.
54 basic number
56 HELLA number
57 Test-1
58 Test-2
59 Test-3
61 freely
62 clamp 15 bits
63 hot light bit
67 Dimmung %
70 freely
73 heating from bit
